6.4 cm (2.5) full-range speaker with a plastic basket and plastic diaphragm. Broad frequency response and good voice reproduction. Particularly well suited to outdoor applications and where ambient conditions are generally unfavourable (e.g. high ...
Magnetically shielded oval fullrange driver with good efficiency and balanced frequency response with a clear highrange reproduction. Extremely small size due to a neodymium magnet system. Applicable as built-in speaker in TV's and PC's with very ...
5 cm (2) full-range speaker with a plastic basket and plastic diaphragm. Broad frequency response and good voice reproduction. Particularly well suited to outdoor applications and where ambient conditions are generally unfavourable (e.g. high ...
6.5 cm (2.5) full-range speaker with minimal mounting depth and small magnet. Balanced frequency response and high efficiency. Very good high range response. Suitable in machines and other equipment where space is at a premium.
13 cm (5) 2-way coaxial loudspeakers with polypropylene cone and polycarbonate tweeter. Integrated crossover (capacitor) for the tweeter. Very balanced sound. Straightforward installation in vehicles with cutouts for 13 cm speakers. Door and rear ...
10 cm (4) 2-way coaxial loudspeakers with 10 cm polypropylene cone and polycarbonate dome tweeter. Integrated crossover (capacitor) for the tweeter. Very balanced sound. Straightforward installation in vehicles with 10 cm cutouts. Door and rear ...
Oval 2-way coax speaker with polypropylene diaphragm and European standard basket. Integrated crossover (capacitor type) for the tweeter. Simple fitting in vehicles with cut-outs for 9 x 15 cm speakers. Includes fitting materials. Typical ...
3-way triaxial highly efficient oval speaker systems featuring polypropylene woofer and conical midrange. Powerful bass and clean-cut higher frequencies. Particularly suited to installation on the rear shelf. Easy to connect thanks to integrated ...
Professional 1 driver with titanium dome, in conjunction with the exponential horn system M 300, as midrange driver above 800 Hz. The 40 mm aluminium-voice-coil and the heavy duty magnet drive are making this system suitable for professional ...
50 mm (2) High-End titanium dome driver for the midrange band between 800 and 5000 Hz. Due to the enormously strong and ultra-light titanium dome and in conjunction with a highly damped surround, linear frequency response and no partial ...
50 mm (2) High-End fabric dome driver for the midrange band between 800 and 7000 Hz. Due to the optimised dome shape with double coating in conjunction with the highly damped surround, linear frequency response and no partial oscillations. Due to ...
100 mm (4) cone midrange driver for the midrange band between 1000 and 5000 Hz. Due to the enclosed rear no separate midrange housing construction is necessary. Extremely good price/performance ratio.
100 mm (4) cone midrange driver for the midrange band between 1000 and 5000 Hz. Due to the enclosed rear no separate midrange housing construction is necessary. Extremely good price/performance ratio in 3-way combinations in conjunction with cone ...
40 cm (15) High-End woofer with black cellulose cone, large magnet and heavy aluminium die-cast basket. Extremely high power handling due to 60 mm voice-coil, capton voice coil carrier and magnet vent.
30 cm (12) High-End woofer with a particularly low resonance frequency. Double cellulose cone, large-scale magnet arrangement and a heavy die-cast aluminium basket. Excellent power-handling capabilities with minimum mechanical power loss due to the ...
30 cm (12) High-End woofer with black cellulose cone, large magnet and heavy aluminium die-cast basket. Extremely high power handling due to 60 mm voice-coil, capton voice coil carrier, vented damper and magnet vent. Easy connection due to the ...
25 cm (10) High-End woofer with black cellulose cone, large magnet and heavy aluminium die-cast basket. Extremely high power handling due to 50 mm voice-coil, capton voice coil carrier and magnet vent.
20 cm (8) High-End woofer with stiff aluminium cone, solid aluminium die-cast basket and elastic rubber surround. Extremely low mechanical and electrical losses due to vented pole plate, vented damper and capton voice coil carrier. Fast pulse ...
