Динамик СЧ/НЧ Visaton GF 250/2x4
25 cm (10") High-End woofer with black glass fiber cone, solid aluminium die-cast basket and elastic rubber surround.
![]() Автоматическая линия Bakeline GF-250 используется на предприятиях пищевой промышленности, в пекарнях и кондитерских для производства хлебобулочных, кондитерских и кулинарных изделий из... | |||
GF-250 | 3 115 000 ₽ | ||
GF-250 | 3 372 973 ₽ | ||
GF250-T3-T | по запросу | ||
GF250 | по запросу |
Designed for multi-purpose applications due to 2 x 4 ohms double voice-coil, with excellent properties as 8 ohms drivers in series configuration. The long stroke voice-coil in conjunction with the extended rear pole plate, the vented damper, the vented magnet and the capton voice-coil carrier guarantees long strokes and highest power handling.
