Клеммные колодки Keen Side
Динамик СЧ/НЧ Visaton TI 100 M/8
10 cm (4") high-end mid-bass unit featuring a completely new type of diaphragm cone made of pure titanium.
Испытательный прибор, THERMAL IMAGER, FLUKE TI100, 9Hz; Temperature Measuring Range: -20℃ to +250℃ ; RoHS Compliant: NA
FLK-TI100 9HZ
Fluke
199 360 ₽
FLK-TI100 9HZ
Fluke
201 069 ₽
S2P-TI100
ТаймЧипс
FLK-TI100 9HZ
The carefully designed cone combines with the shape and material of the surround and the adhesives to avoid cone resonance. The shape of the basket with its large aperture and rear-ventilated centring piece coupled with the open voice coil with its phase plug produce the lowest possible mechanical losses and produce a correspondingly high mechanical Q-factor. As a result of the construction using double magnets the TI 100 M 8 OHM is also magnetically shielded.
In comparison with the TI 100 8 OHM, this unit has a shorter voice coil and a particularly lightweight fabric surround but generates more sound pressure in the medium range.
The TI 100 M 8 OHM is ideal when used as a mid-range unit e.g. in 3-way high-end speakers.
