Datasheet ТI LM101AJ — Даташит
| Серия | LM101A-N |
| Модель | LM101AJ |
Операционный усилитель 8-CDIP от -55 до 125
LM101A/LM201A/LM301A Operational Amplifiers datasheet
PDF, 1.0 Мб, Версия: D, Файл опубликован: 19 мар 2013
- AN-71 Micropower Circuits Using the LM4250 Programmable Op Amp (Rev. B)PDF, 536 Кб, Версия: B, Файл опубликован: 1 май 2013
This application report describes the circuit operation of the Texas Instruments LM4250, various methodsof biasing the device, frequency response considerations, and some circuit applications exercising theunique characteristics of the LM4250. - LM118 Op Amp Slews 70 V/secPDF, 118 Кб, Файл опубликован: 1 окт 2002
LM118 Op Amp Slews 70 V/ГѓВґsec - AN-20 An Applications Guide for Op Amps (Rev. C)PDF, 727 Кб, Версия: C, Файл опубликован: 1 май 2013
This application note is a guide for Op Amps. The circuits discussed herein are illustrative of the versatilityof the integrated operational amplifier and provide a guide to a number of useful applications. Thecautions noted in each section will show the more common pitfalls encountered in amplifier usage. - AN-24 A Simplified Test Set for Op Amp CharacterizationPDF, 1.2 Мб, Файл опубликован: 10 май 2004
Application Note 24 A Simplified Test Set for Op Amp Characterization - AN-29 IC Op Amp Beats FETs on Input Current (Rev. B)PDF, 965 Кб, Версия: B, Файл опубликован: 1 май 2013
This application note describes a monolithic operational amplifier which has input error currents in theorder of 100 pA over a в€’55В°C to 125В°C temperature range. Instead of FETs, the circuit used bipolartransistors with current gains of 5000 so that offset voltage and drift are not degraded. A powerconsumption of 1 mW at low voltage is also featured.A number of novel circuits that make use - AN-32 FET Circuit ApplicationsPDF, 254 Кб, Файл опубликован: 10 май 2004
- AN-4 Monolithic Op Amp—The Universal Linear Component (Rev. B)PDF, 579 Кб, Версия: B, Файл опубликован: 1 май 2013
Operational amplifiers are undoubtedly the easiest and best way of performing a wide range of linearfunctions from simple amplification to complex analog computation. The cost of monolithic amplifiers isnow less than $2.00, in large quantities, which makes it attractive to design them into circuits where theywould not otherwise be considered. Yet low cost is not the only attraction of monoli - AN-241 Working with High Impedance Op AmpsPDF, 169 Кб, Файл опубликован: 3 май 2004
Application Note 241 Working with High Impedance Op Amps - AN-31 Op Amp Circuit Collection (Rev. B)PDF, 2.3 Мб, Версия: B, Файл опубликован: 1 май 2013
This application report provides basic circuits of the Texas Instruments op amp collection. - AN-A The Monolithic Operational Amplifier: A Tutorial StudyPDF, 379 Кб, Файл опубликован: 11 май 2004
- General Purpose Power SupplyPDF, 94 Кб, Файл опубликован: 3 окт 2002
- AN-46 The Phase Locked Loop IC as a Communication System Building BlockPDF, 314 Кб, Файл опубликован: 14 май 2004
- Predicting Op Amp Slew Rate Limited ResponsePDF, 139 Кб, Файл опубликован: 7 окт 2002
- AN-30 Log Converters (Rev. B)PDF, 370 Кб, Версия: B, Файл опубликован: 1 май 2013
One of the most predictable non-linear elements commonly available is the bipolar transistor. Therelationship between collector current and emitter base voltage is precisely logarithmic from currentsbelow one picoamp to currents above one milliamp. Using a matched pair of transistors and integratedcircuit operational amplifiers it is relatively easy to construct a linear to logarithmic conv - AN-79 IC Preamplifier Challenges Choppers on Drift (Rev. B)PDF, 940 Кб, Версия: B, Файл опубликован: 1 май 2013
Since the introduction of monolithic IC amplifiers there has been a continual improvement in DC accuracy.Bias currents have been decreased by 5 orders of magnitude over the past 5 years. Low offset voltagedrift is also necessary in a high accuracy circuits. This is evidenced by the popularity of low drift amplifiertypes as well as the requests for selected low-drift op amps. However until n - Get Fast Stable Response From Improved Unity-Gain FollowersPDF, 107 Кб, Файл опубликован: 2 окт 2002
- AN-103 LM340 Series Three Terminal Positive Regulators (Rev. A)PDF, 814 Кб, Версия: A, Файл опубликован: 6 май 2013
The LM340-XX are three terminal 1.0A positive voltage regulators with preset output voltages of 5.0V or15V. The LM340 regulators are complete 3-terminal regulators requiring no external components fornormal operation. However by adding a few parts one may improve the transient response provide for avariable output voltage or increase the output current. Included on the chip are all of t
Серия: LM101A-N (3)
- LM101AH LM101AH/NOPB LM101AJ
- Semiconductors > Space & High Reliability > Amplifier > Operational Amplifiers
