Оптопары и оптореле Megawin
Datasheets - Аналоговые переключатели, мультиплексоры Analog Devices - 6
Подраздел: "Аналоговые переключатели, мультиплексоры"
Производитель: "Analog Devices"
Серии
AD7511 ADG1201 ADG1204 ADG1206 ADG1207 ADG1208 ADG1209 ADG1211 ADG1212 ADG1213 ADG1219 ADG1221 ADG1222 ADG1223 ADG1233 ADG1234 ADG1236 ADG1308 ADG1309 ADG1311 ADG1312 ADG1313 ADG1334 ADG1401 ADG1402 ADG1404 ADG1406 ADG1407 ADG1408 ADG1409 ADG1411 ADG1412 ADG1413 ADG1414 ADG1419 ADG1421 ADG1422 ADG1423 ADG1433 ADG1434 ADG1436 ADG1438 ADG1439 ADG1519 ADG1604 ADG1606 ADG1607 ADG1608 ADG1609 ADG1611 ADG1612 ADG1613 ADG1633 ADG1634 ADG1636 ADG201A ADG201S ADG333A ADG406 ADG407 ADG408 ADG409 ADG411 ADG412 ADG413 ADG417 ADG419 ADG426 ADG428 ADG431 ADG432 ADG433 ADG436 ADG438F ADG439F ADG442 ADG444 ADG451 ADG452 ADG453 ADG4612 ADG4613 ADG508A ADG508F ADG509F ADG511 ADG512 ADG513 ADG5204 ADG5206 ADG5207 ADG5208 ADG5208F ADG5209 ADG5209F ADG5212 ADG5213 ADG5233 ADG5234 ADG5236 ADG5243F ADG5248F ADG5249F ADG528F ADG5298 ADG5401 ADG5401F ADG5404 ADG5404F ADG5408 ADG5409 ADG5412 ADG5412BF ADG5412F ADG5413 ADG5413BF ADG5413F ADG5419 ADG5421 ADG5421F ADG5423 ADG5433 ADG5434 ADG5436 ADG5436F ADG5462F ADG601 ADG602 ADG604 ADG608 ADG609 ADG611 ADG612 ADG613 ADG619 ADG621 ADG633 ADG636 ADG658 ADG659 ADG701L ADG702L ADG706 ADG707 ADG708 ADG709 ADG714 ADG715 ADG725 ADG726 ADG731 ADG732 ADG733 ADG734 ADG736 ADG7421F ADG758 ADG759 ADG772 ADG774 ADG786 ADG788 ADG798 ADG801 ADG802 ADG824 ADG841 ADG849 ADG852 ADG854 ADG858 ADG888 ADGS1208 ADGS1209 ADGS1212 ADGS1408 ADGS1409 ADGS1412 ADGS1414D ADGS1612 ADGS5412 ADGS5414 LTC1380 LTC1390 LTC1391 LTC1393 LTC201A LTC202 LTC203 LTC221 LTC222 SW201S
Найдено: 192 Вывод: 101-120
Вид: Список / Картинки
  1. Четырехканальная схема защиты с определяемыми пользователем предельными напряжениями, Ron 10 Ом
  2. Высокотемпературный (до 210 C), низковольтный восьмиканальный мультиплексор
  1. Высоковольтный четырехканальный iCMOS SPST ключ с последовательным портом управления, сопротивление 1.5 Ом
  2. Высокотемпературный (до 210 C), высоковольтный восьмиканальный мультиплексор без эффекта защелкивания
  1. Мультиплексор 8:1 с интерфейсом SPI, напряжением питания 15В/+12В, логическими сигналами управления 1.8 В и низкими емкостью/инжекцией заряда
  2. Сдвоенный мультиплексор 4:1 с интерфейсом SPI, напряжением питания 15В/+12В, логическими сигналами управления 1.8 В и низкими емкостью/инжекцией заряда
  3. Четырехканальный ключ SPST ADGS1212 с интерфейсом SPI, малой инжекцией заряда и малой емкостью, питание 15 В/+12 В
  4. Мультиплексор 8:1 с интерфейсом SPI, напряжением питания 15В/+12В/ 5В, логическими сигналами управления 1.8 В и сопротивлением во включенном состоянии 4 Ом
  5. Сдвоенный мультиплексор 4:1 с интерфейсом SPI, напряжением питания 15В/+12В/ 5В, логическими сигналами управления 1.8 В и сопротивлением во включенном состоянии 4 Ом
  6. SPI, 1,5 Ом RON, ±15 В/±5 В/+12 В, восьмеричный однополюсный переключатель высокой плотности
  7. Интерфейс SPI, 1 Ω R ON , ±5 В, 12 В, 5 В, 3,3 В, настраиваемый мультиплексор, переключатель Quad SPST
  8. Интерфейс SPI, 4 переключателя SPST, 9,8 Ом R ON , ±20 В/+36 В, настраиваемый мультиплексор
  9. Восьмиканальный ключ SPST с интерфейсом SPI, R ON 13.5 Ом, питание 20 В/+36 В
  10. Защита от сбоев, 6 Ω R ON , переключатель SPST с каналом обратной связи 0,6 кОм
  11. Защита и обнаружение неисправностей ±60 В, 11 Ом RON, двойной переключатель SPST
  12. Мультиплексор 8:1 с защитой от перегрузки по напряжению, QINJ -0.4 пФ
  13. Защита и обнаружение неисправностей при низком напряжении, 12 Ω R ON , двойной переключатель SPST
  14. Защищенные аналоговые переключатели DI CMOS
  15. Аналоговый переключатель Aerospace Quad SPST JFET
  16. Аэрокосмическая промышленность, 60 Ом, Quad SPST Switch
