It is possible to get 220V AC from 110V AC ?
5 1
22.11.2014 21:20 #1
My power grid is 110 VAC and need only test a stabilizer of up to 800W calling it a network of 220VAC to see if it works normally. I know it's only make an inverter 12v to 220v but need a powerful transformer to the circuit and transformers that have at the moment are burned. Does not exist a more simple way?
2,219 485
17 2
22.11.2014 22:57 #2
ST-1000B Dayton or handmade autotransformer/
211 44
3 5
22.11.2014 23:01 #3
Look, maybe the transformer have central wire of the coil 220v, or have possibility to solder wire to central point, and you can put 110v directly on the half of coil 220v, without nothing.
Тип файла: jpg Trans.jpg (53.6 Кб, 0 просмотров)
Часовой пояс GMT +3, время: 23:23.
