Приборы - Аудио динамики SEAS - 3
Подраздел: "Аудио динамики"
Производитель: "SEAS"
Найдено: 67 Вывод: 41-60
Вид: Список / Картинки
  1. Динамик ВЧ SEAS H883-06 (27TAFC/G)
    27TAFC/G is a High Definition metal dome tweeter with a wide, soft fabric surround and a rear chamber. Aluminium/magnesium alloy diaphragm with pistonic behaviour throughout the audible frequency range, resulting in a good dispersion also above ...
  2. Динамик ВЧ SEAS H881-06 (27TFFC)
    27TFFC is a High Fidelity precoated fabric dome tweeter with an integral wide surround and a rear chamber. Sonolex precoated lightweight fabric diaphragm with high consistency and excellent stability against variations in air humidity. Voice coil ...
  1. Динамик ВЧ SEAS H0414-08 (19TAF/G)
    19mm High Fidelity dome tweeter with smooth, extended frequency response. Aluminium diaphragm suspended by a specially designed soft Sonotex surround which allows a low fundamental frequency. Injection moulded chassis in high grade glass fibre ...
  2. Динамик ВЧ SEAS H0561-08 (19TAF/D)
  1. Динамик ВЧ SEAS H0737-08 (19TFF 1)
    19mm High Fidelity dome tweeter with extremely smooth and extended frequency response. Precoated Sonotex fabric diaphragm and suspension allows for very tight production tolerances and high consistency. Injection moulded chassis in high grade glass ...
  2. Динамик ВЧ SEAS H831-06 (27TFF)
    27TFF is a High Fidelity precoated fabric dome tweeter with an integrated wide surround. Sonolex precoated lightweight fabric diaphragm with high consistency and excellent stability against variations in air humidity. Voice coil windings immersed ...
  3. Динамик ВЧ SEAS Excel E0040-06 (T29CF002)
    The T29CF002, ”CRESCENDO” is an Ultra High End 29mm soft dome tweeter with a HEXADYM magnet system. An optimally shaped dome and integrated wide surround manufactured by SEAS from SONOMEX ensure excellent performance and consistency. A ...
  4. Динамик ВЧ SEAS Excel E0011-06 (T25CF002)
    The T25CF002, “MILLENNIUM” is a 25mm soft dome tweeter with a novel Neodymium based magnet system. A unique HEXADYM magnet system (US Pat 6.020.805 ) based on 6 radially magnetized NdFeB magnet blocks. Efficient ventilation and damping ...
  5. Динамик ВЧ SEAS Excel E0047-04 (T29MF001)
    The T29MF001, “MAGNUM” is a 25mm magnesium dome tweeter with a patented Neodymium based magnet system. It is the tweeter of choice for those who seek extremely precise and realistic sound reproduction combined with a relatively low ...
  6. Динамик ВЧ SEAS Excel E0006-06 (T25CF001)
    The T25CF001 is a 25mm fabric dome with moderately high efficiency. An optimally shaped dome and a wide SONOMEX surround, both manufactured by SEAS, ensure excellent performance and consistency. Low viscosity magnetic fluid which provides excellent ...
  7. Динамик ВЧ SEAS Excel E0036-06 (T25C003)
    The T25C003 is a 25mm fabric dome with moderately high efficiency. It is the tweeter of choice for those who want the most precise and realistic reproduction of the high frequency audio range. A wide, soft polymer surround designed to give high ...
  8. Динамик НЧ SEAS Excel E0026-08S (W26FX001)
    The extremely stiff cone made from aluminium/magnesium alloy gives tremendous bass precision. 2” diameter high temperature voice coil with black anodized aluminium coil former for high power handling and reduced power compression. Heavy ...
  9. Динамик НЧ SEAS Excel E0022-08S (W22EX001)
    Precision cast and surface treated magnesium cone coupled to a natural rubber surround showing no sign of midrange (edge) resonances. Heavy copper rings mounted above and below the T-shaped pole piece reduce non linear and modulation distortion and ...
  10. Динамик НЧ SEAS Excel E0049-08S (W16NX001)
    Precision cast, machined and surface treated magnesium cone acts as a piston through the audible frequency band without showing any sign of midrange resonances. A unique radial reinforced rubber surround reduces radial resonances and prevents ...
  11. Динамик СЧ/НЧ SEAS Excel E0037-08S (W15CH001)
    Precision cast and surface treated magnesium cone coupled to a natural rubber surround showing no sign of midrange (edge) resonances. Patented Hexadym magnet system of acoustically transparent design to avoid cavity resonances and air flow noise. ...
  12. Динамик НЧ SEAS Excel E0045-08S (W22NY001)
    A paper cone with a unique Nextel coating ensures smooth frequency response and low distortion. A large magnet system with a bumped back plate, together with a very long and light weight CCAW voice coil, allow extreme coil excursion with low ...
  13. Динамик СЧ/НЧ SEAS Excel E0017-08S (W18EX001)
    Precision cast and surface treated magnesium cone coupled to a natural rubber surround showing no sign of midrange (edge) resonances. Large magnet system with bumped back plate makes room for extreme coil excursions. Heavy copper rings mounted ...
  14. Динамик СЧ/НЧ SEAS Excel E0018-08S (W18E001)
    Precision cast and surface treated magnesium cone coupled to a natural rubber surround showing no sign of midrange (edge) resonances. Magnet system with bumped back plate makes room for extreme coil excursions. Heavy copper rings mounted above and ...
  15. Динамик СЧ/НЧ SEAS Excel E0042-08S (W18NX001)
    An adaptive rubber surround provides an ideal match to the cone over the total frequency range. A paper cone with a unique Nextel coating ensures smooth frequency response and low distortion. A large magnet system with bumped back plate, together ...
  16. Динамик СЧ/НЧ SEAS Excel E0044-08S (W12CY003)
    A paper cone with a unique Nextel coating ensures smooth frequency response and low distortion. Heavy copper rings mounted above and below the T-shaped pole piece reduce non linear and modulation distortion and increase overload margin. A large ...
