Datasheet Texas Instruments LM35CH — Даташит
СерияLM35
МодельLM35CH
В±0.5В°C Temperature Sensor with Analog Output with 30V Capability 3-TO -40 to 110
Datasheet LM35
PDF, 1.7 Мб, Версия: G, Файл опубликован: 15 авг 2016, Страниц: 36
Precision Centigrade Temperature Sensors
45 предложений от 25 поставщиков
SENSOR ANALOG -40C-110C TO46-3. Temperature Sensor Analog, Local -40°C ~ 110°C 10mV/°C TO-46-3. Temperature Sensors - Analog and Digital Output
LM35CH/NOPB
от 286 ₽
LM35CH
от 1 865 ₽
ТаймЧипс
LM35CH
LM35CH
Pin33
Package TypeNDVNDV
Industry STD TermTO-CANTO-CAN
JEDEC CodeO-MSFM-PO-MSFM-P
Package QTY500500
МаркировкаLM35CHLM35CH
Width (мм)4.6994.699
Length (мм)4.6994.699
Thickness (мм)2.3622.362
Max Height (мм)2.6672.667
InterfaceAnalog Output
Local Sensor Accuracy(Max)0.5 +/- C
Рабочий диапазон температурот -40 до 110,-55 до 150,0 до 100,0 до 70 C
Package GroupTO
Package Size: mm2:W x L3TO: 22 mm2: 4.699 x 4.699(TO) PKG
Supply Current(Max)114 uA
Supply Voltage(Max)30 В
Supply Voltage(Min)4 В
RoHSSee ti.com
  • Thermocouple, Cold-Junction Compensation—Analog Approach
    PDF, 614 Кб, Файл опубликован: 27 авг 2014
    Temperature is the most commonly measured physical parameter in a variety of systems, including automotive, industrial, and consumer domains. There are various temperature transducers available to address the need of accurate temperature measurement. Thermocouples are widely popular because they are inexpensive, have a wide range, are small in size, and do not need excitation. This application not
  • AN-460 LM34/LM35 Precision Monolithic Temperature Sensors (Rev. C)
    PDF, 495 Кб, Версия: C, Файл опубликован: 1 май 2013
    This application report discusses the details and uses of the Texas Instruments LM34 and LM35 asprecision temperature sensors.
  • AN-480 A 40 MHz Programmable Video Op Amp
    PDF, 218 Кб, Файл опубликован: 11 май 2004
  • AN-1852 Designing With pH Electrodes (Rev. A)
    PDF, 115 Кб, Версия: A, Файл опубликован: 1 май 2013
    A pH electrode measures hydrogen ion (H+) activity and produces an electrical potential or voltage. Theoperation of the pH electrode is based on the principle that an electric potential develops when two liquidsof different pH come into contact at opposite sides of a thin glass membrane. This was originallydiscovered in 1906 by Max Cremer [1]. His discovery laid the foundation for Fritz Habe
  • High-Efficiency 3A Battery Chargers Use LM2576 Regulators (Rev. B)
    PDF, 187 Кб, Версия: B, Файл опубликован: 23 апр 2013
    This application report describes two LM2576-based designs that provide up to 3A of current for batterycharging.
  • Sensing and Monitoring for Control and Protection Seminar
    PDF, 245 Кб, Файл опубликован: 17 фев 2003
  • TO-92 Packing Options / Ordering Instructions (Rev. A)
    PDF, 287 Кб, Версия: A, Файл опубликован: 23 июн 2010
  • Semiconductors > Space & High Reliability > Sensors > Temperature Sensor
На английском языке: Datasheet Texas Instruments LM35CH
