Datasheets - РЧ усилители Analog Devices - 7
Подраздел: "РЧ усилители"
Производитель: "Analog Devices"
Серии
AD7293 AD8353 AD8354 ADCA3950 ADCA3952 ADCA3990 ADCA3992 ADH519S ADL5320 ADL5321 ADL5324 ADL5521 ADL5523 ADL5530 ADL5531 ADL5534 ADL5535 ADL5536 ADL5541 ADL5542 ADL5544 ADL5545 ADL5570 ADL5601 ADL5602 ADL5604 ADL5605 ADL5606 ADL5610 ADL5611 ADL5721 ADL5723 ADL5724 ADL5725 ADL5726 ADL7003 ADL8104 ADL8111 ADL8150 ADL9005 ADL9006 ADMV7710 ADMV7810 ADPA1105 ADPA7001-Die ADPA7002 ADPA7004 ADPA7005 ADPA7006 ADPA7007 ADPA9002 ADRF5515 ADRF5545A ADRF5547 ADRF5549 ADTR1107 HMC-ABH209-DIE HMC-ABH241-DIE HMC-ABH264-DIE HMC-ALH102-DIE HMC-ALH140-DIE HMC-ALH216-DIE HMC-ALH244-DIE HMC-ALH310-DIE HMC-ALH311-DIE HMC-ALH313-DIE HMC-ALH364-DIE HMC-ALH369-DIE HMC-ALH376-DIE HMC-ALH382-DIE HMC-ALH435-DIE HMC-ALH444-DIE HMC-ALH445-DIE HMC-ALH476-DIE HMC-ALH482-DIE HMC-ALH508-DIE HMC-ALH509-DIE HMC-APH196-DIE HMC-APH403-DIE HMC-APH460-DIE HMC-APH462-DIE HMC-APH473-DIE HMC-APH510-DIE HMC-APH518-DIE HMC-APH596-DIE HMC-APH608-DIE HMC-APH633-DIE HMC-APH634-DIE HMC-AUH232-DIE HMC-AUH249-DIE HMC-AUH256-DIE HMC-AUH312-DIE HMC-AUH317-DIE HMC-AUH318-DIE HMC-AUH320-DIE HMC1022A-Die HMC1040-Die HMC1040LP3CE HMC1049-Die HMC1049LP5E HMC1082 HMC1086-DIE HMC1086F10 HMC1087-Die HMC1087F10 HMC1099LP5DE HMC1099PM5E HMC1114LP5DE HMC1114PM5E HMC1121 HMC1126 HMC1127 HMC1131 HMC1132PM5E HMC1144-DIE HMC263-Die HMC263LP4E HMC311LP3 HMC311SC70 HMC311ST89 HMC313 HMC326 HMC327 HMC341-Die HMC341LC3B HMC342-Die HMC342LC4 HMC356 HMC3587 HMC3653 HMC372 HMC373 HMC374 HMC374SC70E HMC375 HMC376 HMC382 HMC383-Die HMC383LC4 HMC392A-Die HMC392ALC4 HMC395-DIE HMC396-DIE HMC397-DIE HMC405-DIE HMC406 HMC407 HMC408 HMC409 HMC413 HMC414 HMC415 HMC441-Die HMC441LC3B HMC441LH5 HMC441LM1 HMC441LP3 HMC442-Die HMC442LC3B HMC442LM1 HMC450 HMC451-Die HMC451LC3 HMC451LP3 HMC452QS16G HMC452ST89 HMC453QS16G HMC453ST89 HMC454 HMC455 HMC457 HMC459-DIE HMC460-Die HMC460LC5 HMC461 HMC462-Die HMC462LP5 HMC463-Die HMC463LH250 HMC463LP5 HMC464-Die HMC464LP5 HMC465-Die HMC465LP5 HMC480 HMC487 HMC490-Die HMC490LP5E HMC498-Die HMC498LC4 HMC499-Die HMC499LC4 HMC504 HMC516-Die HMC516LC5 HMC517-Die HMC517LC4 HMC518-DIE HMC519-Die HMC519LC4 HMC549 HMC559-DIE HMC562-DIE HMC564-Die HMC564LC4 HMC565-Die HMC565LC5 HMC566-Die HMC566LP4E HMC5805A HMC589A HMC590-Die HMC590LP5 HMC591-Die HMC591LP5 HMC594-Die HMC594LC3B HMC599 HMC606-Die HMC606LC5 HMC608 HMC609-Die HMC609LC4 HMC618A HMC633-Die HMC633LC4 HMC634-Die HMC634LC4 HMC635-Die HMC635LC4 HMC636 HMC637A-Die HMC637ALP5E HMC637BPM5E HMC639 HMC659-Die HMC659LC5 HMC6981 HMC7054 HMC7149-DIE HMC717A HMC7229-DIE HMC7229LS6 HMC7357 HMC740 HMC741 HMC7441 HMC751 HMC752 HMC753 HMC754 HMC7543 HMC772 HMC7885 HMC788A HMC789 HMC7950 HMC797A-Die HMC797APM5E HMC8142 HMC8205 HMC8325 HMC8400-DIE HMC8401-DIE HMC8402-DIE HMC8410 HMC8410-DIE HMC8411 HMC8412 HMC8415 HMC8500PM5E HMC863ALC4 HMC902-Die HMC902LP3E HMC903-Die HMC903LP3E HMC906A-DIE HMC907A-Die HMC907APM5E HMC920 HMC930A-DIE HMC943APM5E HMC952A HMC962 HMC963 HMC980-Die HMC980LP4E HMC981-Die HMC981LP3E HMC994A-DIE HMC994APM5E HMC998A-DIE HMC998APM5E LTC6430-15 LTC6430-20 LTC6431-15 LTC6431-20 LTC6432-15 LTC6433-15
Найдено: 299 Вывод: 121-140
Вид: Список / Картинки
  1. GaN усилитель мощности, 40 Вт (46 дБм), диапазон частот 9 ГГц 10.5 ГГц
  2. Усилитель мощности GaAs pHEMT MMIC 1/2 Вт, 24–29,5 ГГц
  1. Усилитель мощности диапазона Е с детектором мощности, диапазон частот 71 ГГц 76 ГГц
  2. Усилитель мощности диапазона Е с детектором мощности, 1 Вт, диапазон частот 81 ГГц 86 ГГц
  1. GaAs, pHEMT, MMIC, одноположительный источник питания, усилитель мощности от 0 до 10 ГГц
  2. От 40 ГГц до 80 ГГц, GaAs, pHEMT, MMIC, широкополосный усилитель мощности
  3. 46 дБм (40 Вт), от 0,9 до 1,6 ГГц, усилитель мощности на основе GaN
  4. GaAs InGaP HBT-усилитель-драйвер SMT, 3,0 - 4,5 ГГц
  5. Усилитель MMIC с блоком усиления InGaP HBT, постоянный ток - 6 ГГц
  6. InGaP HBT Gain Block Amplifier SMT, DC - 8 ГГц
  7. Микросхема усилителя GaAs pHEMT MMIC с низким уровнем шума, 18–32 ГГц
  8. GaAs pHEMT MMIC малошумящий усилитель, 18 - 31 ГГц
  9. Усилитель MMIC с блоком усиления HBT, 7–15 ГГц
  10. Малошумящий усилитель диапазона 400 МГц – 4000 МГц
  11. Усилительный блок ВЧ/ПЧ диапазона 50 МГц - 4.0 ГГц
  12. Усилительный блок ВЧ/ПЧ диапазона 30 МГц - 6 ГГц
  13. Усилительный блок ВЧ/ПЧ диапазона 30 МГц - 6 ГГц
  14. От 0,01 ГГц до 10 ГГц, MMIC, GaAs, блок усиления ВЧ-сигнала pHEMT
  15. Усилитель с фиксированным коэффициентом усиления в корпусе для поверхностного монтажа, диапазон от нуля до 4 ГГц
  16. Усилитель с низким уровнем шума, от 0,01 ГГц до 10 ГГц
