Источники питания Keen Side
Приборы - Аудио динамики Visaton - 5
Подраздел: "Аудио динамики"
Производитель: "Visaton"
Найдено: 117 Вывод: 81-100
Вид: Список / Картинки
  1. Динамик СЧ/НЧ Visaton W 130 S/8
    13 cm (5) HiFi low-midrange driver with coated paper cone, elastic rubber surround and 25 mm voice-coil. Suitable as woofer and due to the very balanced frequency response also as low-midrange driver especially in large 3-way speaker systems.
  2. Динамик СЧ/НЧ Visaton W 130 S/4
  1. Динамик СЧ/НЧ Visaton W 100 S/8
    10 cm (4) HiFi low-midrange driver with coated paper cone, elastic rubbersurround and 20 mm voice-coil. Suitable as woofer in mini-speaker systems and due to the very balanced frequency response especially suitable as low-midrange driver in 3-way ...
  2. Динамик СЧ/НЧ Visaton W 100 S/4
    10 cm (4) HiFi low-midrange driver with coated paper cone, elastic rubber surround and 20 mm voice-coil. Suitable as woofer in mini-speaker systems and due to the very balanced frequency response especially suitable as low-midrange driver in 3-way ...
  1. Динамик СЧ/НЧ Visaton TI 100 M/8
    10 cm (4) high-end mid-bass unit featuring a completely new type of diaphragm cone made of pure titanium. The carefully designed cone combines with the shape and material of the surround and the adhesives to avoid cone resonance. The shape of the ...
  2. Динамик СЧ/НЧ Visaton TI 100/8
    10 cm (4) High-End low-midrange driver featuring a diaphragm cone made of pure titanium. The carefully designed cone combines with the shape and material of the surround and the adhesives to avoid cone resonance. The shape of the basket with its ...
  3. Динамик СЧ/НЧ Visaton MR 130/8
    130 mm (5) cone midrange driver for the midrange band between 1000 and 5000 Hz. Due to the enclosed rear no separate midrange housing construction is necessary. Very good price/performance ratio.
  4. Динамик СЧ/НЧ Visaton GF 250/2x4
    25 cm (10) High-End woofer with black glass fiber cone, solid aluminium die-cast basket and elastic rubber surround. Designed for multi-purpose applications due to 2 x 4 ohms double voice-coil, with excellent properties as 8 ohms drivers in series ...
  5. Динамик СЧ/НЧ Visaton AL 170/8
    17 cm (6.5) High-End low midrange driver with stiff, anodized aluminium cone, solid aluminium die-cast basket and elastic rubber surround. Extremely low electrical and mechanical losses due to vented pole plate, vented damper and capton voice-coil. ...
  6. Динамик СЧ/НЧ Visaton AL 130/8
    13 cm (5) High-End low midrange driver with stiff, anodized aluminium cone, solid aluminium die-cast basket and elastic rubber surround. Extremely low electrical and mechanical losses due to vented pole plate and vented damper. Capton voice-coil ...
  7. Динамик СЧ/НЧ Visaton WS 13 E/8
    13 cm (5) low-midrange driver with paper cone and elastic rubber surround. Due to the special basket design especially suitable as replacement driver for many HiFi speakers.
  8. Динамик СЧ/НЧ Visaton WS 17 E/8
    17 cm (6.5) HiFi woofer with coated paper cone, elastic rubber surround and inverse dust-cap. Due to the balanced frequency response also suitable as low-midrange driver for 4-way speaker systems. Due to the special basket design especially ...
  9. Динамик СЧ/НЧ Visaton W 170 S/4
    17 cm (6.5) HiFi woofer with coated paper cone, powerful drive and extended rear pole plate. Special voice-coil and elastic rubber surround for long strokes.
  10. Динамик СЧ/НЧ Visaton W 170 S/8
  11. Динамик СЧ/НЧ Visaton W 170/8
    17 cm (6.5) HiFi woofer with very good price/performance ratio. Suitable for simple 2-way speakers and car rear tray systems. Especially suited als replacement driver for many HiFi speakers.
  12. Динамик СЧ/НЧ Visaton W 170/4
  13. Динамик СЧ/НЧ Visaton R 10 S/8
    10 cm (4) fullrange speaker with high efficiency and balanced frequency response. Especially suitable as control speaker for electronic devices. Typical applications: - Control speakers for electronic devices - Ceiling- mounted speakers in railway ...
  14. Динамик СЧ/НЧ Visaton K 50/8
    5 cm (2) miniature speaker with plastic diaphragm and metal basket. Thanks to its compact dimensions, suitable for signal output in machines and other equipment where space is at a premium. Typical applications: - Voice and signal output in ...
  15. Динамик НЧ Visaton TIW 360/8
    30 cm (12) High-End woofer with black cellulose cone, large magnet and heavy aluminium die-cast basket. Extremely high power handling due to 60 mm voice-coil, capton voice coil carrier, vented damper and magnet vent. radiation pattern 500 Hz ...
  16. Динамик НЧ Visaton TIW 250 XS
    25 cm (10) high-end woofer. The extra-wide elastic surround, the long voice coil and particularly large magnet arrangement give this speaker extremely long excursion. Thanks to the multiple venting of the voice coil (pole piece hole, holes in the ...
