Design Note DN530 July 2014 Jesus Rosales, Willie Chan Linear Technology's isolated µModule converters are compact solutions for breaking ground loops. These converters employ a flyback architecture whose maximum output current varies with ...
Application Note AN142 November 2013 Christian Kueck Switching regulators replace linear regulators in areas where low heat dissipation and efficiency are valued. The switching regulator is typically the first active component on the input power ...
Application Note 142 August 2013 Bob Dobkin Regulators regulate but are capable of doing much more. The architecture of linear regulators has remained virtually unchanged since the introduction of the three terminal floating voltage regulator in ...
Application Note 138 October 2013 Trevor Barcelo An inductive wireless power system consists of a transmitter that generates a high frequency alternating magnetic field and a receiver that collects power from that field. The resonant coupled system ...
Это несложное устройство предназначено для контроля питания +5 В. Монитор напряжения выдает информационные сигналы TTL уровня, сопровождающиеся индикацией светодиодов, показывающих, что напряжение или отклонилось от номинального значения, или ...
This simple TTL power supply monitor circuit monitors the 5-volt level TTL power line and gives a signal whether the supply voltage is outside or within the necessary range or “window”. The heart of the power supply monitor is a ...
