Новости Mini-Circuits - 2
Производитель: "Mini-Circuits"
Найдено: 21 Вывод: 11-20
  1. For your signal distribution needs in UHF, cellular, GPS, satellite communications, and more, Mini-Circuits has expanded our offering with the ZC24PD-222+ coaxial 24-way 0 splitter/combiner. This new model covers frequencies from 650 to 2200 MHz ...
    1 марта 2014
  2. In our continued effort to bring our customers more options in off-the-shelf cable solutions, Mini-Circuits has introduced the 141-SMNB series to our line of Hand-Flex™ system interconnect cables. N-type female bulkhead connector with rugged, ...
    24 февраля 2014
  1. Mini-Circuits’ new RC-Series of switch matrices incorporates both Ethernet and USB control into six catalog models, expanding our offering and giving you more options. These models support communication via HTTP and Telnet network protocols, ...
    20 февраля 2014
  2. Радиочастотные компоненты Mini-Circuits CMA-545G1+ CMA-5043+ CMA-162LN+ CMA-252LN+
    Mini-Circuits held tested to meet MIL requirements for gross leak, fine leak, thermal shock, vibration, acceleration, mechanical shock, and HTOL, 4 new MMIC amplifiers in our CMA-series give you ultra-low noise figures and outstanding reliability ...
    16 января 2014
  1. Mini-Circuits ZFRSC-4-842+ 4 way 0 resistive power splitter/combiner expands frequency coverage to support even more applications and meet your needs. This new model provides: Very wide frequency range, DC to 8400 MHz Low VSWR, 1.15:1 typ. Low ...
    3 января 2014
  2. Mini-Circuits released extended the frequency coverage of our tiny wideband surface mount transformers to serve even more applications and give you more choices. The TCM3-452X+ provides a secondary/primary impedance ratio of 3:1; the TCM4-452X+ ...
    19 декабря 2013
  3. Mini-Circuits SYPJ-2-33+ 2 way 180 hybrid adds extended frequency coverage to our splitter/combiner lineup, covering 50Ω applications from 500 to 3000 MHz. This model provides: Very low amplitude unbalance (0.5 dB typ.) Very low phase ...
    15 декабря 2013
  4. Mini-Circuits released RHP-700+ surface mount high pass filter is built with high-Q capacitors and air coil inductors for superior performance. It provides low pass band insertion loss (0.6 dB typ.), and high stop band rejection (30 dB typ.). It ...
    7 декабря 2013
  5. The new Mini-Circuits PMA2-33LN+ amplifier utilizes E-PHEMT technology to achieve a unique combination of ultra-low noise, high gain, high IP 3 , and tiny size. It features: Wide frequency range, 0.4 3.0 GHz Ultra-low noise figure, 0.38 dB High ...
    6 декабря 2013
  6. Mini-Circuits released signal generator with Ethernet control, AM, PM, FM, and pulse modulator. The SSG-6400HS is a DDS-based, USB and Ethernet controlled, ultra-wideband signal generator. This high performance model offers: Frequency range from ...
    5 декабря 2013
